Agilex 7 devices design example programming failed.
- 2 years ago
Hi Eric,
I have tested the design example from my end and it is successful.
- Please used Quartus Pro version 24.1 as suggested for the design example.
- Upgrade you IP tool. I saw from your photo there is a pop up suggested to upgrade IP.
- Run the design example again.
Aiman
-Can you share the screenshot of the error message?
-Has the design ever work before?
-What is the Quartus version that you used?
-Make sure to select the correct device (AGFB014R24B2E2V)
Aiman
- Eric_1002 years ago
Hi
Here are screenshots of the error message.How can I fix this error message?
I am using Quartus Pro Edition and NIOS V for the first time.
I have used Quartus Prime Lite Edition and NIOS II before and did not have this problem.
My Quartus version is Prime Pro 23.4.0 Build 79 11/22/2023 SC Pro Edition.
The Device ID is correct.Thx.,
Eric
I have had a go at building the same system with Quartus Prime Lite and it can be successfully compiled.
Why does compilation always fail when using Quartus Prime Lite?
Eric
Why does compilation always fail when using Quartus Prime Pro?
Eric
