suppamax
2 years agoAgilex 5 no cost license - unable to generate programming file
I am about to start a project targeting Intel Agilex 5 series E FPGA.
I have Quartus Prime Pro 21.1 freshly installed on my computer and I have generated a no cost license for Agilex 5.
I tested the setup using the example design included in the SW.
The implementation flow had no problem till the generation of the programming file
Error(23714): Can not generate programming files for your current project because you do not have a valid license. Visit the Intel FPGA Self-Service Licensing Center at https://licensing.intel.com Warning(115005): Unlicensed IP: "Nios V/m Microcontroller Intel FPGA IP (6AF7 D036)" Warning(115004): Unlicensed encrypted design file: "/home/max/Workarea/quartus_dummy/hw_m/qdb/_compiler/top/root_partition/24.1.0/final/1/netlist.model" Warning(115004): Unlicensed encrypted design file: "/home/max/Workarea/quartus_dummy/hw_m/qdb/_compiler/top/root_partition/24.1.0/final/1/names.model" Warning(115004): Unlicensed encrypted design file: "/home/max/Workarea/quartus_dummy/hw_m/qdb/_compiler/top/auto_fab_0/24.1.0/final/1/netlist.model" Warning(115004): Unlicensed encrypted design file: "/home/max/Workarea/quartus_dummy/hw_m/qdb/_compiler/top/auto_fab_0/24.1.0/final/1/names.model"
Could you please explain me what I am supposed to do?
In my project I am not planning on using NIOS-V. I want to integrate my own code and only add a PLL and a DDR controller. Would the generated license be enough for this?
