Agilex™ 7 R-Tile Compute Express Link* (CXL*) FPGA
1. Yes I am using the FPGA dev kit to deploy the CXL design that is already implemented . My assumption was that the hardware will be plug and play unless I need to change something in the design on the FPGA. I am using Quartus 23.1 . I have been following this manual "Agilex™ 7 FPGA I-Series Development Kit User Guide" . I see the license listed on Intel® FPGA Self-Service Licensing Center. The problem right now is that I do not have a computer associated with this fixed license.
When I try to add a new host , I see a window and I do not understand the fields here . Is there a document that I could follow to fill these in ?
2. Once I have access to this I would like to enable the inherent cxl design and try using it . I hope the path I am following to get this thing work is the right one.
3. Yes, the system I am using supports cxl and other cxl 2.0 devices work on it .
