17 years agoThe feasibility of an alternative method depends on the maximum sampling frequency that you can apply to the input data. The more you oversample the input, the more you will be accurate in clock and data recovery. But certainly, as FvM says, it is difficult to suggest you an appropriate solution without knowing well your application.
