8 years agoAdding nets to signaltap via HDL
Is it possible to add nets for signaltap debugging using VHDL attributes ?2 Replies
Do you want attributes to be monitored using signaltap? Hope below links helps you. https://alteraforum.com/forum/showthread.php?t=53741 Refer session 7.1ftp://ftp.altera.com/up/pub/tutorials/de2/digital_logic/tut_signaltapii_vhdlde2.pdf Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation) - Altera_Forum
If you are referring to mark_debug attributes that xilinx uses, then no. Altera let's you search for nets from different lists, either HDL, synth or p&r net names. Altera also tends to preserve names logically rather than the terrible names xilinx come up with.
