12 years agoYou can compile a testbench automatically from Quartus. Add the testbench to your Quartus project. Then go to the menu:
Assigments->Settings->Simulation go to "Compile TestBench" click on TestBench and the add the testbench, etc... When you compile your project again your testbench will compile too. And you can start Model Sim form Menu: Tools->Run EDA Tool Simulation Toot->EDA RTL Simulation. Also, if you do a timing simulation, you can set it to open Model Sim automatically after Compilation.
