17 years agovizzie is mistaken. The Component Editor in SoPC builder can be used to create custom components based on HDL code or by simply exporting the bus. If you are getting errors when adding your .vhd file in the component wizard, you should read what those errors are and find and fix them in your HDL code.
I've created hundreds of HDL-based SoPC builder components. Trust me it works. Jake
