14 years agoActive parallel/serial configuration of FPGA
Hi friends,
In QUartus II,When i set configuration as Active parallel/serial,the dual purpose pins get set according to the chosen configuration.It means the flash pins which are used to configure FPGA,get assigned to nodes by default(i.e. with node names which start like this ~ALTERA_pinname~). So,i am not able to assign those pin to the exact location in the assignment editor/pin planner.If i assign,Fitter gives an error as "can't locate multiple nodes to the same pin". but without assigning them to exact locations,if i run the fitter,i'm getting a warning as " those pins are not assigned to the exact location".Will this cause any problem while flashing the program. Please reply me,if anyone knows about thjs?
