--- Quote Start ---
Hi GPK
I looked into signal probe, but didn't have too much luck. It seems the destination wants to be a pin, and I need it to be a port to another module. I need to connect to a module that serializes the data for the external DAC.
Tricky...I'll give the assignment editor a try, maybe some type of ECO.
I wounder how Altera does it with the SignalTap II Logic analyzer?
Thanks for you help,
Lindy
--- Quote End ---
Hi Lindy,
I think I misundertand you. I though that you would like to see the internal signal directly on device pins, in order to measure the signals with e.g. a scope. It seems to me that you want to connect an additional block to internal signals of your design and the block is on the toplevel , right ?
Kind regards
GPK
