10 years agoAccessing individual nodes in a bus
Hi How can the individual nodes on a bus be accessed? Is using LPM_DECODE the only way? Thanks
10 years agoTricky
I think I got going in the direction I want if there is not a better way https://www.alteraforum.com/forum/attachment.php?attachmentid=12012 by modifying the symbol file by adding q_0 unless there is a better way Roger50310 ENTITY CntMod4 IS PORT ( clock : IN STD_LOGIC ; cnt_en : IN STD_LOGIC ; q : OUT STD_LOGIC_VECTOR (2 DOWNTO 0); q_0 : OUT STD_LOGIC ); END CntMod4; ARCHITECTURE SYN OF cntmod4 IS SIGNAL sub_wire0 : STD_LOGIC_VECTOR (2 DOWNTO 0); COMPONENT lpm_counter GENERIC ( lpm_direction : STRING; lpm_modulus : NATURAL; lpm_port_updown : STRING; lpm_type : STRING; lpm_width : NATURAL ); PORT ( clock : IN STD_LOGIC ; cnt_en : IN STD_LOGIC ; q : OUT STD_LOGIC_VECTOR (2 DOWNTO 0); q_0 : OUT STD_LOGIC ); END COMPONENT; BEGIN q <= sub_wire0(2 DOWNTO 0); LPM_COUNTER_component : LPM_COUNTER GENERIC MAP ( lpm_direction => "UP", lpm_modulus => 4, lpm_port_updown => "PORT_UNUSED", lpm_type => "LPM_COUNTER", lpm_width => 3 ) PORT MAP ( clock => clock, cnt_en => cnt_en, q => sub_wire0, Q_0 => sub_wire0(0) );
