14 years ago
Access violation message when opening simulation report
I created a simple project using Quartus II v11.1. I then created a simple simulation file using Qsim and did the simulation. I got messages that simulation was successful and then it went to open Quartus II to view the simulation output file. I got an internal error saying:
*** Fatal Error: Access Violation at 0X651449A4
Module: qwedt.exe
Stack Trace:
0x1449a3: QPrinter::setDocName + 0x23 (QtGui4)
0x53813: QString::fromLatin1_helper + 0x63 (QtCore4)
0x2720f: QUI_FRAME_WND::set_window_title + 0x59f (SYS_QUI)
0x70fc9: QUI_FRAME_WND::open_file + 0x89 (SYS_QUI)
0x25421: edt_wedtq_create_frame_wnd + 0xa11 (edt_wedtq)
0x3543: MEM_SEGMENT_INTERNAL::locked_allocate + 0x83 (ccl_mem)
0x3873: MEM_SEGMENT_INTERNAL::allocate + 0x43 (ccl_mem)
0x378e: mem_new_wrapper + 0x5e (ccl_mem)
0x6fff2: QUI_APP::init_instance + 0x3d2 (SYS_QUI)
0x1c51: msg_main_thread + 0x11 (CCL_MSG)
0x1be8: _thr_final_wrapper + 0x8 (ccl_thr)
0x1bc5: msg_thread_wrapper + 0x85 (CCL_MSG)
0x443a: mem_thread_wrapper + 0x4a (ccl_mem)
0x2b5d1: msg_exe_main + 0x81 (CCL_MSG)
0x13399: BaseThreadInitThunk + 0x11 (kernel32)
0x39ed1: RtlInitializeExceptionChain + 0x62 (ntdll)
0x39ea4: RtlInitializeExceptionChain + 0x35 (ntdll)
End-trace
Quartus II 32-bit Version 11.1 Build 173 11/01/2011 SJ Full Version
I am clueless, please help!
Note: I am logged in as an admin user.
    I got the same error. Qsim only runs on V 10.1 or V11.0. Hopefully you still have one of those versions installed.
    Fortunately I had V11.0 and V11.1 on another computer so I had to uninstall V11.1 first, then re-install qsim being careful that it gets installed in the V11.0 subdirectory or it wont get found. Everything runs fine on V11.0 now.
    I wrote to the university program to hope that they fix it and relist the availabilty to download the archive V9.1 which had the simulator built in.
    Thanks for the reply. Yes I remember that Qsim used to work under v11.0. The problem is that in v11.0 there is a silly bug when you try to create a symbol from a schematic file it refuses and displays an error. The workaround was to convert this schematic to HDL then create the symbol from that HDL.
    The good news is that Altera has just released v11.1 SP1 which solves the Qsim bug!
    SOLVED :)
    I'm still having the same issue, even with SP1 installed:
    Module: qwedt.exe
    Stack Trace:
         0x428a: mem_thread_wrapper + 0x4a (ccl_mem)
    End-trace
    Quartus II 32-bit Version 11.1 Build 216 11/23/2011 SJ Web Edition
    Service Pack Installed:  1
    Do you have any suggestions?
    Thanks!
    Matt
    I think it may still have something to do with running version 11.1 I had to run version 11.0 to get it to work
    Ok, I was hoping it had already been fixed. Where do I go on the Altera site to download 11.0? Most of the links I had were for 11.1sp1 only. I'm TAing a class starting after the new year and I'd like to make it as easy as possible for them, so if there's a easy link to the 11.0 download, that'd really help.
    Thanks!
    Matt
