14 years agoThanks for the reply. Yes I remember that Qsim used to work under v11.0. The problem is that in v11.0 there is a silly bug when you try to create a symbol from a schematic file it refuses and displays an error. The workaround was to convert this schematic to HDL then create the symbol from that HDL.
The good news is that Altera has just released v11.1 SP1 which solves the Qsim bug! SOLVED :)
