13 years ago --- Quote Start --- I want to reference the path of a separate file (not the TCL script) in order to add it with the add_fileset_file command. Using a path relative to the location of the TCL script would work, but would not be elegant at all since the file to be added is several layers of hierarchy away. --- Quote End --- That was the situation I was also faced with. It would be nicer if the Tcl interpreter preserved the environment variables, but it doesn't. --- Quote Start --- I will probably submit a service request with Altera. --- Quote End --- Please post their response here. I'd like to see a more elegant solution too :) Cheers, Dave
