13 years agoI found the same issue, but never had time to look into it much further.
The following command might be useful to you to use as a work around (if all you want is the path to the _hw.tcl file):
set path_to_script ]]
where 'info script' gives you the _hw.tcl file, 'file normalize' gives you the full path to that script, and 'file dirname' strips off the _hw.tcl name. At that point, you can use names relative to the _hw.tcl location. Cheers, Dave
