13 years agoEasiest way would be to try an avoid big models, like the PLL. It tends to be slow. Provide the clocks yourself.
If its a system level test, probably not a lot you can do.Easiest way would be to try an avoid big models, like the PLL. It tends to be slow. Provide the clocks yourself.
