8 years ago
Academic Q: Why doesn't Quartus Synthesis Allow Some Restricted Classes?
Was pleased to discover SV supports scalable tasks/functions to the extent that if you bury it in a class you can set the 'type' by parameter.
Why then can't this be synthesized? For example, why can't I synthesize this:
    class generic# (type T=logic);
        static function int find_first_msb(input T vector);
            for(int i=$bits(vector)-1;i>=0;i--)
                if(vector)
                    return i;
            return -1;
        endfunction//find_first_msb
    endclass
    msb  = generic#(uint32)::find_first_msb(decimal);
Rather, I have to create a fixed-width version.
    function int find_first_msb(input uint32 vector);
            if(vector)
                return i;
        return -1;
There's nothing to prevent this limited (but useful!) functionality from being synthesized.
~SysTom
    I don't think classes are supported for syntheses at all.
    Static class methods are synthesizable in other tools, but apparently not in the tool you are using. They allow you to have parameterizable functions.
    Thanks Tricky, dave_59.
    Yep, the tool is Quartus.
    Thanks again, Tom
