14 years agoThe /incremental_db directory stores post-fit information and is common to all designs(meaning you have no choice but to store them there). Please file an SR, as the archive should be pointing to them with relative paths.
One thought is that you could export the partition as a .qxp. Now it's not in the /incremental_db, but a single file that can be added to your project just like it's a source file. Finally though, .qxp files made from encrypted IP still need the source IP to look at(and it has to be in the same path as the original) and you still need a license. It's supposed to work that it can't be used to get around not having a license.
