12 years ago --- Quote Start --- you need sign extend: data_24 <= std_logic_vector(resize(signed(data_23)),24) + resize(signed(data_23b)),24); --- Quote End --- actually i have tried a simple code as you have mentioned above as below library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.numeric_std.ALL; ---- Uncomment the following library declaration if instantiating ---- any Xilinx primitives in this code. --library UNISIM; --use UNISIM.VComponents.all; entity project1 is port(a:in STD_LOGIC_vector(23 downto 0); b:in STD_LOGIC_vector(23 downto 0); z:out STD_LOGIC_vector(24 downto 0)); end project1; architecture Behavioral of project1 is begin z<=STD_LOGIC_vector (resize(signed(a)),24)+resize(signed(b)),24); end Behavioral; and the error i have got is ERROR:HDLParsers:3324 - "D:/projects final/signextension/project1.vhd" Line 42. IN mode Formal NEW_SIZE of resize with no default value must be associated with an actual value. ERROR:HDLParsers:3324 - "D:/projects final/signextension/project1.vhd" Line 42. IN mode Formal NEW_SIZE of resize with no default value must be associated with an actual value. ERROR:HDLParsers:854 - "D:/projects final/signextension/project1.vhd" Line 42. The expression can not be converted to type STD_LOGIC_vector. ERROR:HDLParsers:3324 - "D:/projects final/signextension/project1.vhd" Line 42. IN mode Formal NEW_SIZE of resize with no default value must be associated with an actual value. ERROR:HDLParsers:3324 - "D:/projects final/signextension/project1.vhd" Line 42. IN mode Formal NEW_SIZE of resize with no default value must be associated with an actual value. ERROR:HDLParsers:164 - "D:/projects final/signextension/project1.vhd" Line 42. parse error, unexpected CLOSEPAR, expecting SEMICOLON Process "Check Syntax" failed What is the problem with my code can you suggest me?
