13 years ago --- Quote Start --- My guess is that the first integrator will have benefit of interpolation by 8 i.e. you need to insert 7 zeros after every sample before you apply it to the first integrator and hence the gain is reduced. --- Quote End --- So can you give the solution for the problem for the overflow in the second integrator stage?
