13 years ago --- Quote Start --- After further work it turned out that my last statement needs correction. The best thing is run this matlab program and read (d): Bin = 23; %input width N = 9; %stages of comb or integrator M = 1; %differential delay R = 8; %interpolation rate %cic decimator at any stage Bout = N * log2(R*M) + Bin; %cic interpolator per ith stage %stages 1~N for i = 1:N G = 2^i; Bout = Bin + log2(G); d(i) = Bout; end %N+1 ~ 2N stages for i = N+1:N*2 G = (2^(2*N-1)*(R*M)^(i-N))/R; Bout = Bin + log2(G); d(i) = Bout; end for i = 1:N*2 fprintf('%i %i\r',i,d(i)); end --- Quote End --- after checking the matlab code above the value of d is as below 1 24 2 25 3 26 4 27 5 28 6 29 7 30 8 31 9 32 10 40 11 43 12 46 13 49 14 52 15 55 16 58 17 61 18 64 Now my question is with 23 bit input data how to write vhdl code so that the ouput data width is 24 and follows.Since addition of 2 23 bit input data as shown in the comb section of the cic interpolation is 23 bit data and if i specify output data widthto be 24 there will be syntax error while synthesizing the vhdl code that datatypes are not matching.Can you give solution for this problem?
