10 years ago
About VGA Output
I am working for the first time with FPGA (cyclone v soc) and i am trying to get a output from VGA Port on the monitor. I have set the resolution for 1024x768 and PLL input frequency as 50MHz and output frequency as 65MHz as required for the resolution.But as soon as i program the board the monitor is going to sleep mode. I am attaching the code which i used for this. Can you please tell me what may be the problem. When I checked in RTL Simulation PLL is not generating any clock output.
Thank you in advance.
Code:
----Main code
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.NUMERIC_STD.ALL;
ENTITY VGA IS
PORT(
CLOCK_24: IN STD_LOGIC;
SYS_rst : IN STD_LOGIC;
VGA_HS, VGA_VS: OUT STD_LOGIC;
VGA_R, VGA_G, VGA_B: OUT STD_LOGIC_VECTOR(7 DOWNTO 0);
VGA_CLK_65MHZ : OUT STD_LOGIC
END VGA;
ARCHITECTURE MAIN OF VGA IS
SIGNAL VGACLK, RESET, lock : STD_LOGIC :='0';
signal SIGNAL_135MHZ : STD_LOGIC:= '0';
COMPONENT SYNC IS
PORT
CLK : IN STD_LOGIC;
HSYNC, VSYNC : out std_logic;
R, G, B : OUT STD_LOGIC_VECTOR(7 DOWNTO 0)
END COMPONENT;
component unsaved is -- PLL Component
port (
pll_0_locked_export : out std_logic; -- pll_0_locked.export
pll_0_outclk0_clk : out std_logic; -- clk
pll_0_refclk_clk : in std_logic := '0'; -- clk
pll_0_reset_reset : in std_logic := '0' -- reset
end component unsaved;
BEGIN
inst_pll : UNSAVED port map
pll_0_refclk_clk => clock_24,
pll_0_reset_reset => SYS_rst,
pll_0_outclk0_clk => VGACLK, ---CLOCK 65 MHZ
--outclk_1 => SIGNAL_135MHZ, --- CLOCK 135 MHZ
pll_0_locked_export => lock
INST_SYNC : SYNC PORT MAP
CLK => VGACLK,
HSYNC => VGA_HS,
VSYNC => VGA_VS,
R => VGA_R,
G => VGA_G,
B => VGA_B
VGA_CLK_65MHZ <= VGACLK;
END MAIN;
---Sub Program
LIBRARY IEEE;
ENTITY SYNC IS
PORT(
CLK : IN STD_LOGIC;
END SYNC;
ARCHITECTURE MAIN OF SYNC IS
SIGNAL HPOS: INTEGER RANGE 0 TO 1344:=0;
SIGNAL VPOS: INTEGER RANGE 0 TO 806:=0;
BEGIN
PROCESS(CLK,HPOS,VPOS)
BEGIN
IF(CLK' EVENT AND CLK='1') THEN
IF (HPOS = 832 OR VPOS = 422) THEN
R <= (OTHERS => '1');
G <= (OTHERS => '1');
B <= (OTHERS => '1');
ELSE
R <= (OTHERS => '0');
G <= (OTHERS => '0');
B <= (OTHERS => '0');
END IF;
IF(HPOS<1344) THEN
HPOS <= HPOS+1;
ELSE
HPOS <=0;
END IF;
IF (VPOS<806)THEN
VPOS <= VPOS+1;
ELSE
VPOS <=0;
END IF;
END IF;
IF (HPOS > 24 AND HPOS < 160)THEN
HSYNC <= '0';
ELSE
HSYNC <= '1';
END IF;
IF (VPOS > 3 AND VPOS < 9) THEN
VSYNC <= '0';
ELSE
VSYNC <= '1';
END IF;
IF ((HPOS> 0 AND HPOS< 320) OR (VPOS>0 AND VPOS< 38)) THEN
END IF;
END PROCESS;
END MAIN;
    hello,
    I connected my FPGA board to monitor through VGA cable. Before programming when i connect the board to the monitor its showing the default logo of Altera FPGA board. As soon as i download the program into the board the monitor is going to power saving mode.
    I am using DELL LCD monitor E1912HC.
    You're missing my point, pnayak15. Look at the pinout for a VGA connector:
    https://en.wikipedia.org/wiki/vga_connector
    That pinout certainly does not match your FPGA output. This is an analog interface, not DVI/HDMI as I suspected. So your FPGA output is driving the input to a video encoder chip on your board. Please find out what that chip is, get a data sheet, and make sure you're using the chip correctly (giving it all of the proper input signals that it needs).
    Hello sir,
    The VGA chip I am using is 'ADV7123' 10-bit video DAC. Since I am very new to VHDL programming and FPGA board I'll take little more time to understand you. I will heck those things told by you and get back to u soon in case if I need any further help. Please bear with me.
    pnayak15 -
    Ok, now we're getting somewhere. It sounds like you have an Altera dev kit. And when you power up the board the dev kit displays the Altera logo on the monitor. Do you have the source code for the FPGA design that came with the board? Normally that is provided with a dev kit. If you have that then look at it and see what's different from what you're doing, especially how sync is generated. The ADV7123 does not take VSYNC and HSYNC, which is what you are generating. It needs composite sync, which is basically VSYNC and HSYNC combined into one signal, with a few specific differences. Once you drive SYNC/ correctly you should get an image. And you'll also need to drive the BLANK/ signal high.
    Good luck, you're getting close!
    Bob
    Hi
    Yeah exactly I have that Altera DE kit. I have to see about that source code and also I will work on that combined hsync and vsync signal.
    Thank you sir. If anything I could not find please help me..
    Prashant
    hello,
    I didnt get source code for VGA along with the board. do we have to include that sync and blank signals in our program????
    Prashant -
    It looks like you don't need to generate composite sync after all. Vsync and Hsync go directly to the VGA connector. But both the SYNC/ and BLANK/ inputs to the ADV7123 are driven by the FPGA so you have to do something with them. Read the ADV7123 data sheet. And you can download the FPGA source code from TerasIC if you have an account.
    You have all the information you need to make this work, and you're close. Not much else I can do for you. Maybe this video will help:
    https://www.youtube.com/watch?v=wk5ft5rd1su
    Bob
    hello,
    Thank you so much sir for your help. I will try with that and get back to you.
    Prashanth
