12 years ago --- Quote Start --- I'm sorry for the description fault, the tool calculate the required time is as follows: 2ns(max_delay) - 3ns(output_delay) = -1ns; And the arrived time is as follows: 3ns(input_delay) + tDELAY; So tools think the constraints should be: 3ns(input_delay) + tDELAY < -1ns => tDELAY <-4ns; But my thinking is that I want to constraint the max delay time is 2ns from ina to oub (tDELAY < 2ns), so, for that, I need to constraint the max_delay is 8ns; It is right? --- Quote End --- I don't see how you found out what the tool is thinking. set_input_delay has nothing to do with tdelay path. It is meant for register path only, so is set_output_delay. And in both cases it has nothing to do with concept of pure delay. set_input_delay is information to the tool about data/clock offset arriving at pins. set_output_delay is information to the tool about allowed range of data/clock offset ejected at output pin. The path of tdelay is comb. from pin to pin and I suppose it will be dealt with independant of register path. Whether you get it or not is up to your luck but still I don't understand the merits of your approach from basic design perspective. May be you tell us what is the purpose of your constraints...
