10 years agoabout time quest constraints
Hi to all. I have a little question. I have cyclonevgt dev board. I have to connect a D/A converter to pins of fpga. I create a PLL clock out 100Mhz, routed at a pin of fpga. I create a...
10 years ago --- Quote Start --- Hi, there are two ways I could interpret your text:
- the clock is generated with a PLL inside the FPGA, and an FPGA output brings it to the DAC, or
- the clock is generated with a PLL outside the FPGA, and it is routed to an FPGA input pin as well as the DAC clock input
- the clock is generated with a PLL inside the FPGA, and an FPGA output brings it to the DAC.
