Yamada1
2 years agoAbout the "set_false_path" command
It would be helpful if you could tell me about the options of the "set_false_path" command. 1)It is explained that the -setup,-hold option specifies Setup(Recovery) and Hold(Removal) as False paths...
- 2 years ago
My apologize for not understand your previous question correctly.
Correct me if I am wrong. This look like asynchronous input to the synchronizer logic.
Setting false path to the [asynchronous input paths to synchronizer logic] (path 1) should be sufficient.
Richard Tan
Yamada1
2 years agoThank you for answering.
Thank you for your kind response.
