About the "set_false_path" command
- 2 years ago
My apologize for not understand your previous question correctly.
Correct me if I am wrong. This look like asynchronous input to the synchronizer logic.
Setting false path to the [asynchronous input paths to synchronizer logic] (path 1) should be sufficient.
Richard Tan
Richard Tan
Thank you for answering.
Thank you for responding to my repeated questions.
I was told that all I had to do was set the phallus path for path 1 in the diagram I presented last time, so I recognized that the following description was OK.
set_false_path -from [get_ports {data}] -to [get_pins {reg1|datain}]
If there is no problem, I would appreciate it if you could let me know.
