16 years ago --- Quote Start --- Yes I see. You should measure in a real hardware setup, if any power saving is achieved with clock gating versus clock enable. If it's still meaningful, all options of clock gating have been discussed. The preferred way is with clock control blocks, otherwise you have to an increased effort to achieve timing closure. If FIFOs would be required for synchronization, the power saving effect is most likely exhausted. --- Quote End --- Yes, I agree with you. :) :) Anyway, I tried ALTCLKCTRL to use the 'ena' to switch the clk on and off. But the device I am using is Cycloneiii. The usage of ALTCLKCTRL has to be specified as either global or exteranl. If as global, the amount has to be less than 10; if externl, output pins must be assigned. Neither of them is suitable for this design. :confused: :confused:
