16 years agoclock control blocks are there to put clock back on clock networks. It is up to you to cross domains safely. with so many domains you create, it is likely you will run in trouble. The benefit of power savings may be too trivial. You can have an idea about that in the power analyser. You can use dc fifos across domains
