16 years ago --- Quote Start --- Hi : I am now trying to implement clock gating to a large design. There are 15 basic blocks which works almost in serial sequence. I planed to do the clock gating for them individually. The global clock is out of a PLL and splitted into 15 clock gating unit and the output of each goes into each blocks. The problem is these 15 sub-clocks must be synchronized and now there is some timing violation which seems that they are not. I wonder if there is some constraints to do before synthesis or some smarter way in implenment the clock gating for this design Thank you very much:) :) :) --- Quote End --- Hi, I also would recommend to use clock enable signals otherwise you will run into a lot of timing issues like Hold time violations. Kind regards GPK
