About altera_pll in quartus 15.1.0.185
Folks, help me please! I lost few days from my life. I not sleeping and reading manuals..... I have simple question.
I create simple project, based on altera_pll with default megawizard settings. 2 input pins(clk & reset) and 2 out pins (out & locked). Problem in functional simulation this simple theme in latest version of Quartus. In prev version - all seems to be working. Folks, explain if possible this situation. Problem is my own hands or this is software bug? I have this: $ cat transcript # OpenFile ydpll.vho# Load canceled vlib work vcom -reportprogress 300 -work work /home/triod/yd/ydpll_sim/ydpll.vho# Model Technology ModelSim ALTERA vcom 10.4b Compiler 2015.05 May 27 2015# Start time: 23:39:22 on Nov 20,2015# vcom -reportprogress 300 -work work /home/triod/yd/ydpll_sim/ydpll.vho # -- Loading package STANDARD# -- Loading package TEXTIO# -- Loading package std_logic_1164# -- Loading package altera_lnsim_components# -- Compiling entity ydpll# -- Compiling architecture RTL of ydpll# End time: 23:39:22 on Nov 20,2015, Elapsed time: 0:00:00# Errors: 0, Warnings: 0 vsim work.ydpll# vsim work.ydpll # Start time: 23:39:36 on Nov 20,2015# Loading std.standard# Loading std.textio(body)# Loading ieee.std_logic_1164(body)# Loading altera_lnsim.altera_lnsim_components# Loading work.ydpll(rtl)# Loading sv_std.std# ** Error: (vsim-3733) /home/triod/yd/ydpll_sim/ydpll.vho(303): No default binding for component instance 'ydpll_altera_pll_altera_pll_i_639'.# The following component generic is not on the entity:# PLL_CTR_RESYNC# Time: 0 ps Iteration: 0 Instance: /ydpll/ydpll_altera_pll_altera_pll_i_639 File: nofile# Error loading design# End time: 23:39:37 on Nov 20,2015, Elapsed time: 0:00:01# Errors: 1, Warnings: 0 [ydpll_sim]$ My test project attached.9 Replies
Since previous version work, you can use it as workaround for the time being. If same design pass in old version but fail in newer version. You can file a service requets to MySupport.
I can confirm that problem.
Simulation models of PLLs generated with Quartus (both 15.0 Web Edition and 15.1 Lite Edition) - do not work with Modelsim ALTERA STARTER EDITION 10.4b - but do work with Modelsim ALTERA STARTER EDITION 10.3d I get an error message as described above as well. Is there a service request for that already? - Altera_Forum
You have to edit .do file in simulation folder
--- Quote Start --- You have to edit .do file in simulation folder --- Quote End --- Sorry, but I have to do what? - Altera_Forum
You have to edit my_project_run_msim_rtl_vhdl.do into simulation/modelsim directory.
This is an example of working file:
You have to verify that pll_sim directory path is righttranscript off if ! { file mkdir bemicro-cv-a9_iputf_libs } if {} { vdel -lib rtl_work -all } vlib rtl_work vmap work rtl_work vcom "C:/FPGA/project_dir/pll_sim/pll.vho" if {} { vdel -lib pll -all } vlib pll vmap pll pll vcom -2008 -work pll {C:/FPGA/project_dir/pll.vhd} vlog -vlog01compat -work pll +incdir+C:/FPGA/project_dir/pll {C:/FPGA/project_dir/pll/pll_0002.v} vcom -2008 -work work {C:/FPGA/project_dir/my_file.vhd} # .. VHDL files vsim -t 1ps -L altera -L lpm -L sgate -L altera_mf -L altera_lnsim -L cyclonev -L rtl_work -L work -voptargs="+acc" top_tb +nowarnTFMPC # where top_tb is testbench file to run - Altera_Forum
Was there a solution to this? I'm getting...
** Error: (vsim-3733) H:/work/PROJ/CJLp/source/pll_85m_sim/pll_85m.vho(303): No default binding for component instance 'pll_85m_altera_pll_altera_pll_i_639'.# # The following component generic is not on the entity:# PLL_CTR_RESYNC# Time: 0 ps Iteration: 0 Instance: /cjlp_tb/uut/u_pll/pll_85m_altera_pll_altera_pll_i_639 File: nofile# Loading work.pll_10m(rtl)# ** Error: (vsim-3733) H:/work/PROJ/CJLp/source/pll_10m_sim/pll_10m.vho(305): No default binding for component instance 'pll_10m_altera_pll_altera_pll_i_1098'. for the three different pll's I'm using. I've checked that the paths are correct like suggested. There is no PLL_CTR_RESYNC generic anywhere as it's complaining about? I'm also using quartus 15.1.0.185 with ModelSimAE. It's like it's not picking up the right underlying model. - Altera_Forum
The error is NOT that you are missing a PLL_CTR_RESYNC generic on the altera_pll entity, the problem is that there is an PLL_CTR_RESYNC generic on the iopll_bootstrap component down inside the altera_lnsim_components.vhd file.
I found a solution to this by editing the altera_lnsim_components file. Find the following: component iopll_bootstrap generic( PLL_CTR_RESYNC : integer := 1; PLL_AUTO_RESET_ON_LOSS_OF_LOCK : integer := 0 ); Comment out the PLL_CTR_RESYNC generic and recompile both this file and your PLL. That should get you past your issue. - Altera_Forum
I'm running into exactly the same error. I'm using Quartus 15.1.0 and ModelSim 14.0b Altera Starter Edition on an Linux.
But I can't find the altera_lnsim_components.vhd file mentioned in the post above to comment out the PLL_CTR_RESYNC : integer := 1; line. Are there any more experiences/suggestions on that topic. I can't believe that this is a Quartus Bug, as there are so few results when searching for this issue on the forum... - Altera_Forum
