a10gx board installation failed
I follow to install,although at "Installing kernel driver module... " and "Installing board drivers..." gives "install: completed successfully" however there are some errors during install,so I am not really sure install truly successful.Here is install log: --------------------------------------------------------------- C:\Users\source>aocl installDo you want to install C:\intelFPGA_pro\17.1\hld\board\a10_ref? [y/n] y aocl install: Running install from c:/intelFPGA_pro/17.1/hld/board/a10_ref/windows64/libexec +------------------------------------------------------++ Performing initial checks... ++------------------------------------------------------++------------------------------------------------------++ Installing kernel driver module... ++------------------------------------------------------+WDREG utility v10.21. Build Aug 31 2010 14:21:54Processing HWID *WINDRVR6Installing a signed driver package for *WINDRVR6CM_Get_DevNode_Status ret value 0, status 1802401, problem 1cLOG ok: 1, ENTER: DriverPackageInstallALOG ok: 1, ENTER: DriverPackageInstallWLOG ok: 1, Looking for Model Section [DeviceList.NTamd64]...LOG ok: 1, RETURN: DriverPackageInstallW (0xE000024B)LOG ok: 1, RETURN: DriverPackageInstallA (0xE000024B) difx_install_preinstall_inf: err e000024b, last event 0, last error 0. UNKNOWNinstall: completed successfully+------------------------------------------------------++ Installing board drivers... ++------------------------------------------------------+WDREG utility v10.21. Build Aug 31 2010 14:21:54Processing HWID PCI\VEN_1172&DEV_2494&SUBSYS_A1511172&REV_01Installing a non-signed driver package for PCI\VEN_1172&DEV_2494&SUBSYS_A1511172&REV_01Device node (hwid:PCI\VEN_1172&DEV_2494&SUBSYS_A1511172&REV_01): does not exist and is not configured. Pre-installing.LOG ok: 1, ENTER: DriverPackagePreinstallALOG ok: 1, ENTER: DriverPackagePreinstallWLOG ok: 1, RETURN: DriverPackagePreinstallW (0xE000022F)LOG ok: 1, RETURN: DriverPackagePreinstallA (0xE000022F) difx_install_preinstall_inf: err e000022f, last event 0, last error 0. UNKNOWNinstall: completed successfully+------------------------------------------------------++ ****** SUCCESS! Please reboot your system +-------------------------------------------------------------------------------After install, I try to use aocl diagnose, and get diagnose.exe system error: can't find altera_a10_ref_mmd.dll---------------------Warning:No devices attached for package:C:\intelFPGA_pro\17.1\hld\board\a10_ref---------------------Even I reinstall 2 times and get same message.When I use clinfo in command, get-------------------Platform Name: Intel(R) FPGA SDK for OpenCL(TM)ERROR: clGetDeviceIDs(-1)-------------------
If you haven't connected the board yet, you should not expect the driver installtion or "aocl diagnose" to work correctly.
