15 years ago --- Quote Start --- Hi, the feature itself ( keeping the wire ) is available in all synthesis tools I know. The syntax is sometimes different. Looking for the keyword "keep" should be sufficient to find the right syntax. Kind regards GPK --- Quote End --- OK, pletz. I will put that in mind. Finally, the design has no hold violations any more, thanks to you the warm-hearted. Thank you again. I really appreciate it.:)
