15 years ago --- Quote Start --- Ah, Thank you so much! I really appreciate your help! :) I only remember that there is a way to keep the registers from being synthesis away. There is really a way to keep a wire during synthesis. Thank you! I will try! By the way, " /* synthesis keep */" is just suitable for quartus II only or can be used even in other software? --- Quote End --- Hi, the feature itself ( keeping the wire ) is available in all synthesis tools I know. The syntax is sometimes different. Looking for the keyword "keep" should be sufficient to find the right syntax. Kind regards GPK
