15 years ago --- Quote Start --- Hi, I would use the post-synthesis netlist, because there you have all node which "survived" the synthesis. An other option is to preserve the node. You cando that with the attribute wire keep_wire /* synthesis keep */; for verilog signal keep_wire : std_logic; attribute keep: boolean; attribute keep of keep_wire: signal is true; for VHDL Kind regards GPK --- Quote End --- Ah, Thank you so much! I really appreciate your help! :) I only remember that there is a way to keep the registers from being synthesis away. There is really a way to keep a wire during synthesis. Thank you! I will try! By the way, " /* synthesis keep */" is just suitable for quartus II only or can be used even in other software?
