15 years ago --- Quote Start --- Hi, pletz. Thank you for showing me the way. I tried the assignment editor just now, but when I assign the output pin of the gating cell as a global clock, it shew in yellow(The Help tells that the node I am trying to specify is not found in the netlist), But I really found the pin in the node finder! ( The filter is set to pre-synthesis) And after compilation, the report shows that it is still not using the global routing resource(there is still enough global resource left). Is it that I should not search that pin in the pre-synthesis netlist? Then which type of netlist should I use to specify as a global clock? Please help me. Now I have to constrain the output of the gated clock as a new clock in my '.sdc' file. And this time it worked. --- Quote End --- Hi, I would use the post-synthesis netlist, because there you have all node which "survived" the synthesis. An other option is to preserve the node. You cando that with the attribute wire keep_wire /* synthesis keep */; for verilog signal keep_wire : std_logic; attribute keep: boolean; attribute keep of keep_wire: signal is true; for VHDL Kind regards GPK
