15 years ago --- Quote Start --- Hi, you should check some setting. Assignments -> Settings -> Fitter settings set Optimize hold timing to "All paths" Kind regards GPK --- Quote End --- Hi, pletz. Thank you for your advise. I have followed the Timing Advisor and selected the "All paths". Maybe it is because that I used a gated clock and I did not constrain it. And so the gated clock has a relatively large skew if it drives registers via non-global clock dedicated routing resource?
