15 years ago --- Quote Start --- Hi, pletz, thank you so much. I think I understand what is going on now! Thank you so much. I will check the 5 different paths. And good news is, the hold violation disappear after recompilation. Thanks again for your help. I learned so much today:) Best Regards. --- Quote End --- Hi, you should check some setting. Assignments -> Settings -> Fitter settings set Optimize hold timing to "All paths" Kind regards GPK
