14 years agoA Question in regards to set_false_path
Hi all,
I've got a question about the use of set_false_path in TimeQuest Analyzer. I understand if two clocks are totally asynchronous, I should set_false_path to them and let the analyzer not consider them. But what if I have to clocks both generated from a PLL based on the same clock? For example, if I've clk1 33.33Mhz used as the base clock in a PLL and it generates clka(133Mhz) and clkb(66Mhz). The frequency of clka is twice as much as that of clkb. In this case, should I set_false_path to them?
