14 years ago --- Quote Start --- My quartusII version is 11.0. I'm afraid that the problem in this case is not related to the Quartus libraries compatibility. --- Quote End --- Modelsim 6.0c is ancient. Quartus 11.0 ships with 6.6d, and 11.1 ships with a 10.x version (I forget which). Start by trying the Altera edition. I've never run into the code size limits when debugging and testing individual components of a design, and that is pretty much all you need to check to determine if this is a modelsim issue or quartus generation issue. Cheers, Dave
