14 years ago --- Quote Start --- Which version of Quartus? Its important to use *exactly* the same version of Modelsim as the Altera Starter Edition. I have had troubles using a newer version of Modelsim-SE with Quartus libraries. So, start by trying a consistent version of Modelsim (or try Modelsim Altera Starter Edition). Cheers, Dave --- Quote End --- My quartusII version is 11.0. I'm afraid that the problem in this case is not related to the Quartus libraries compatibility. It is a syntax error. I will try modelsim-altera ase later. But the ASE version has a limitation on the size of simulation codes. It may not solve my problem. Any other solutions?
