TSvob
6 years agoA one bit in vector is not assigned when assigment is out of the process
CheckOnes_P: process(gray_vector, no_ones_below)
begin
for i in 1 to WIDTH_C loop
no_ones_below(i) <= no_ones_below(i-1) and not gray_vector(i-1);
end...
RichardT_altera
6 years agoVHDL uses a process to model signal assignments that are based on an event and the signal assignments do not take place until the process ends.
TSvob
6 years agoSure, I know it, but assigment can be also done outside the proces. Note, that line 8 is placed outside the process - it will cuase (in simulation) that bit 0 is not assigned (it get U value)
begin
end loop;
--- no_ones_below(0) <= '1';
end process;
