16 years ago
A little help please...
I am a recent convert to Altera from Xilinx (hush my mouth) but my last design was in 1994. I have a few questions that just don't seem to be answered in simple terms :
1. Say I have a schematic (.bdf) with 50 i/o pins all labelled. I then convert to a symbol (.bsf) and insert on top level sheet. Do I have to attach labelled pins for all of the i/o on the top level sheet also?
2. I am embedding a NIOS II processor. I have used an example that came with a development board (Cyclone II) which has a PIO 8 outputs). Now I have added another PIO (8 inputs) and hit "Generate". All is fine except when I convert the NIOS II schematic to a symbol it has an extra "ds_MISO_from_the_epcs_controller" that wasn't there originally (The EPCS controller was, but there was nothing on the symbol block). Can I safely ignore it, and if so how do I not display it on the symbol.
3. I am putting a lot of work into this. Can I safely assume that the Quartus web version (free) will not ask me for $$ or time limit or anything like that?
Andrew
    For 1, you can right-click -> Generate Pins for Symbols. All the I/O will be added to that top-level.
    For 3., there won't be anything new. Some features and devices are not enabled with the web editiion, but it's not like something will become disabled.
    Not sure on 2.
    Thank-you that was helpful...but to keep the top level uncluttered, iis it compulsory to regenerate the i/o pins on the top level symbol or can I leave the pins one layer down?
    Only ports on the top-level will connect to I/O. If you don't hook them up, they will be considered hanging(unless you give them a default) and will be synthesized out. Basically, yes.
