10 years ago8 bit counter veriloge code
Hello Dears, pleas I need help for build and design an 8-bit synchronous counter and display the output on DE2-70 board by LEDs, 7-segments and LCD, and quatus 13.0. if there is full verilog co...
10 years agoMakram -
Hi Makram - There are some problems with your counter logic but you'll figure that stuff out over time. To drive the 7-segment display you just need to decode your 4-bit counter to generate a 7-bit vector that drives the display. This data sheet has a truth table that tells you basically what you need to do: http://www.nxp.com/documents/data_sheet/hef4511b.pdf I hope this helps. Bob
