Are you looking for any version in particular?
64 bit versions for linux have been around longer than windows as far as I can tell. - Altera_Forum
I'm looking for a one in Windows. Does Quartus II 12.1 Sp1 support 64 bit processing?
If so, kindly clarify on how to do that. - Altera_Forum
Yes. It installs the 32 and 64 bit versions during installation. Then you just run the correct one.
and 64 bit windows quartus has been around since at least 2009 or 2010
thanks tricky for your response. But when I tried to compile a Arria V design (5AGXFB3H6F35C4), I got following error message
"Error (11371): Compiling a design on Arria V 5AGXFB3 requires at least a 64-bit version of the Quartus II software." Does it have anything to do with the license? i mean For 64-bit version is any specific licenses required? - Altera_Forum
can the 64 bit version be run in Windows Xp?
Have you loaded the 64-bit version of quartus? It is separate to the 32 bit version.
You will need XP 64bit to load the 64 bit version. (and also 64bit win 7 etc)
Okay. I understand. Can you pls tell how to load the 64 bit version? Should it be done during installation?
I have tried giving quartus --64bit <*.qpf> and quartus_map --64bit<*.qpf> from command prompt. it did not work and prompted an error message that "64 bit flag can be used with this executable". - Altera_Forum
you need 64 bit windows. DO you have winXP64?
