yes.
The 64 bit version allows you to access more than 3GB of ram. - Altera_Forum
Ok thanx..tricky then i will install a 64 bit windows 7 OS for 64 bit quartus.. :)
Hi
I am using windows 7 and i want to run quartus in 64 bit . Do i need a 64 bit OS because i am not able to run Quartus 64 bit in windows 7 32bit OS.yes.
The 64 bit version allows you to access more than 3GB of ram.Ok thanx..tricky then i will install a 64 bit windows 7 OS for 64 bit quartus.. :)
