Altera_ForumHonored Contributor14 years ago64 bit OS required for 64bit quartus II Hi I am using windows 7 and i want to run quartus in 64 bit . Do i need a 64 bit OS because i am not able to run Quartus 64 bit in windows 7 32bit OS.
Altera_ForumHonored Contributor14 years agoOk thanx..tricky then i will install a 64 bit windows 7 OS for 64 bit quartus.. :)
Recent DiscussionsHow to fix Error(23782): Failed to find an expected reportMailbox Client IP - SEND_CERTIFICATE command through FPGA fabricQuartus Prime license rehosted, unable to runFailed to run ip-setup-simulation:Connection bit order between hierarchy
