11 years agoThe following is the trace with 5CGXFC5C6 Program/Configure checked; EPCS64 Program/Configure checked, verify checked and Blank Check checked
Info (209060): Started Programmer operation at Thu Dec 11 09:20:45 2014 Info (209016): Configuring device index 1 Info (209017): Device 1 contains JTAG ID code 0x02B020DD Info (209007): Configuration succeeded -- 1 device(s) configured Info (209018): Device 1 silicon ID is 0x16 Info (209044): Erasing ASP configuration device(s) Info (209019): Blank-checking device(s) Info (209023): Programming device(s) Info (209021): Performing CRC verification on device(s) Info (209011): Successfully performed operation(s) Info (209061): Ended Programmer operation at Thu Dec 11 09:22:40 2014 The following is the trace with EPCS64 verify checked right after the above process, without restart. Info (209060): Started Programmer operation at Thu Dec 11 09:27:15 2014 Info (209018): Device 1 silicon ID is 0x16 Info (209021): Performing CRC verification on device(s) Info (209011): Successfully performed operation(s) Info (209061): Ended Programmer operation at Thu Dec 11 09:27:26 2014 The following is the trace with EPCS64 verify checked, after restart. Info (209060): Started Programmer operation at Thu Dec 11 09:29:21 2014 Error (209062): Flash Loader IP not loaded on device 1 Error (209012): Operation failed Info (209061): Ended Programmer operation at Thu Dec 11 09:29:21 2014 Thanks,
