11 years agoWe are using the quartus programmer with the windows gui. Initially we activate the Program/Configure, Verify and Blank-check boxes. We press start. The programmer configures the serial prom and verifies. We then uncheck the Program/Configure and Blank check boxes only leaving the verify checked. Press start again and it passes the verify check.
We then power down the board and power back up. The FPGA loads via the serial prom. We press start again and it fails. Only the Verify box checked.
