11 years agoA couple of questions:
Where does your FPGA boot from - serial/parallel boot ROM, programming cable? What 'verification' does it pass - is this some run-time check or something related to the FPGA programming? By 'rebooted' - what do you mean? Soft restart of some internal logic; reconfiguration of FPGA; full power cycle? How are you determining 'the boards are still working okay' after reboot? Are you using any Altera IP and do you have the relevant license to use it? You've not posted in the wrong place but a little more info might help. Cheers, Alex
