11 years ago
4 bit Ring Counter
Alright I really need help on this.I have installed the 13.4 Xilinx version and I have a code for a 4 bit ring counter and its testbench. When I try implementing the code I get those errors:
ERROR:Security:11 - No 'xc7a8' feature version 2012.01 was available for 'ISE',
ERROR:Map:258 - A problem was encountered attempting to get the license for this
architecture.
. The code used for the counter is:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
entity ring_counter is
port (
DAT_O : out unsigned(3 downto 0);
RST_I : in std_logic;
CLK_I : in std_logic
end ring_counter;
architecture Behavioral of ring_counter is
signal temp : unsigned(3 downto 0):=(others => '0');
begin
DAT_O <= temp;
process(CLK_I)
begin
if( rising_edge(CLK_I) ) then
if (RST_I = '1') then
temp <= (0=> '1', others => '0');
else
temp(1) <= temp(0);
temp(2) <= temp(1);
temp(3) <= temp(2);
temp(0) <= temp(3);
end if;
end if;
end process;
end Behavioral;
I think that i need to adapt the code for this newer version of Xilinx but im not sure how to do that.Or what do I need to change in it to adapt it to the new version?
The code is written and simulated in Xilinx 10.1 which I cannot find anymore.
Thanks a lot!
