3D RAM memory support
Hello.
We are currently using Intel Arria 10 FPGA for our projects. For designing and programming it we have Quartus Prime Pro v21.1.0 Build 169.
Does it support 3D memory technology and >=64GB RAM memories? If not, is there a chance of supporting such memories in newer versions of Quartus Prime software?
Mark
- ShengN_altera
Hi Mark,
Yes. 3D RAM is supported. In Text Editor, you may go to Insert Template -> SystemVerilog -> Full Designs -> RAMs and ROMS to check on 3D RAM template. Below attached one of the ram template (check pic).
The maximum memory bits supported is not larger than 2**31 (2147483648) bits. Also, the largest device memory bits only until 271810560 bits. >=64GB RAM memories I think you mean external memory.
Error(22123): Netlist error at mixed_width_ram.sv(27): ram 'ram' with size larger than 2**31 bits is not supported for blasting
Sheng
- ushermark
Hello Sheng,
I am newbie in developing systems using FPGA and Quartus Prime software. Therefore, it would be nice to have an example project with included 3D RAM as EMIF.
Could you also explain a bit more the limitation of RAM by 2**31 bits?
Mark
- ShengN_altera
Hi Mark,
Regarding EMIF, you may need to open a new thread in this forum https://community.intel.com/t5/FPGA-Intellectual-Property/bd-p/fpga-intellectual-property with title target EMIF to get the help from EMIF expert.
The limitation by 2**31 bits only on RAM inferred with the software because each device has limited memory bits. But external memory don't have this limitation.
Sheng
- ushermark
Hello Sheng,
Thank you for the answer.
I have sent a request to my colleagues, if they got a required information from this topic. I will mark it solved as soon as I recieve a feedback from them during this week.
Mark
